Problem with ScanRouter Lite V2 - The logon user and the Administrator do not match
  • thaonguyen_vt
    I install successfully The ScanRouter Lite V2 program on my win 7 ultimate 64 bit computer, but i have a problem when i click "Resume Serveces" it notices that "Unable to start the dilivery serve since the logon user and the administrator set for the serve do not match. Log on again with your correct user name". My Ricoh Aficio 2020D still get IP of this computer and i can scan documents but it doesn't come to folder i set on the computer.
    Anybody help me !!!
    Thank for your helps !
  • daveyball
    • May 2009
    • 314
    Re: Problem with ScanRouter Lite V2 - The logon user and the Administrator do not ma
    I'm pretty sure that Scanrouter won't work on that platform, and indeed is no longer supported.
    • TonerMunkeh
      Professional Moron
      • 3865
      You could try running it in XP compatability mode, but as daveyball says, it probably won't work. Upgrade your machine to something that doesn't use steam to power it or use scan to email.
      Hit it.
      • thaonguyen_vt
        Thank you very much, i'm trying install it with win 7 32 bit, it still worked few day ago and i've just installed win 7 64 bit after the computer died 'cause virus haizzz
        Thanks again !
