Ricoh mp 3500 ardf problem
  • william1979
    • Jul 2025
    Hi, i have a mp 3500 but ardf, does not work, you place the original and press star not work, but if you put up the ardf and then put down it work, is the same for all copi
  • mikadonovan
    • May 2008
    • 2931
    Re: Ricoh mp 3500 ardf problem
    If it's showing a misfeed, clean the sensor cups in the adf, the two with the black felt patches. They collect paper dust and cause misfeeding problems.
    I just noticed this was not for a MP C3500, which is what I was referencing. Sorry
    NEVER ASSUME ANYTHING
    • sandmanmac
      • 3981
      Your question is a bit unclear...
      Are you saying that you can open and close the ADF and then place originals, and it works? But then the next time you use it it doesn't work again? Or that you can only make copies by placing your originals directly on the contact glass?
      • william1979
        yes, ARDF replace today for another and the same thing happens, i can say that is not the ARDF, what can be?
        • william1979
          ok is a ricoh mp 3500, but, ARDF replace today for another and the same thing happens, i can say that is not the ARDF, what can be?
          • kannuki2
            • Feb 2012
            • 398
            Did you also replace the technician? Haha j/k...
            Print out smc report sp5990-4 and check for what jam code indicate in the original jam.
            • Iowatech
              Not a service manager
              • 3930
              Make sure the ARDF/platen cover closed sensor is clean and undamaged. I've never seen that, but I've seen the actuator for that sensor get knocked out of position or damaged several times, causing the machine to not be able to determine if the ARDF was closed. But opening and closing the ARDF would sometimes knock the actuator back into position, allowing the original documents to feed.
              Also, make sure you are using the correct ARDF for that machine. Many ARDFs look similar, but have very different internals.
              • intracopy2
                Good morning if I understood there is a problem with the photocell feeder! Proper feed is the 3010! see the photocells at the base of the feeder (which is 2 cell)! Another case is the gear that drives the upper lid of the feeder ... (Meaning that we clean up all the photocell feeder ago): D
                • william1979
                  I'll do,
                  • william1979
                    I do this, all, I'll tell you when it resolved
                    • JustManuals
                      • Jan 2006
                      • 9838
                      This Parts & Service manual can now be purchased for $12.77 and downloaded immediately after payment from:
                      Paul@justmanuals.com
