LCD black
  • jrob416
    • May 2011
    • 112
    LCD black
    I have a Ricoh MP C4500 that comes to a ready state, but has no display under the touchscreen. The start button and the function selection buttons are lit, but the touchscreen is not blank. I have swapped user panel, IOB, and BCU with no luck.
  • ruben
    The New Guy
    • Oct 2012
    • 1204
    Re: LCD black
    Faulty polygon motor, you will need to replace the BICU as well. Replacing just the motor will not cure the problem, and replacing just the BICU will damage it.
    • sandmanmac
      • 3969
      Re: LCD black
      Agreed!
      You may want to take another BICU with you, just in case it's been cooked again by the defective polygon
      • Debs1964
        • Oct 2010
        • 1687
        Re: LCD black
        x2 on that
        There are 10 types of people in this world, those who understand binary maths and those who don't
        • jaim3naps
          • Feb 2013
          • 29
          Re: LCD black
          agreed.. i used my flashlight to to find out anything i the screen and i can see error SC202 and its polygon motor, replaced the whole scanner laser unit (used one) and power up still the same problem, so i replaced the BICU board (from old machine) and make sure you follow the procedure in replacing the board and also input the serial number of the machine in SP mode. then restart the machine and its working fine..
          • sandmanmac
            • 3969
            Re: LCD black
            Excellent! Now wouldn't it be special if the poster would provide a little feedback, or (heaven forbid) appreciation for the advice?
            • cwilson
              • Jun 2012
              • 50
              Re: LCD black
              you know you can go through the WIM and see the service codes on there, right?
              But I cleaned the scan glass.......
              • Oze
                Ricoh Fanboy
                • Jul 2008
                • 1663
                Re: LCD black
                I chuckled over the flashlight too
                • locodelacolina
                  • Apr 2013
                  • 7
                  Re: LCD black
                  hello,
                  you need to change BICU and polygon motor at a time.
                  luck!
                  • jaim3naps
                    • Feb 2013
                    • 29
                    Re: LCD black
                    Originally posted by locodelacolina
                    hello,
                    luck!
                    Best way to do yes, do first the polygon motor because if polygon motor is already bad it could damage your BICU and was thinking that bad polygon causes the BICU to break and causes the LCD to turn black.
                    Make sure replace polygon motor first or the laser unit then the BICU..
