Ricoh aficio 2045
  • khaled_abosere3@yahoo.com
    Head technical support
    • Mar 2012
    • 171
    [Jamming] Ricoh aficio 2045
    When printing paper counter or any paper noted that after the exit of the paper there bending by 2 centimeters and as if pressed paper and writing be replaced bending, but inside there is no bending writing
  • JustManuals
    • Jan 2006
    • 9838
    Re: Ricoh aficio 2045
    Huh?
    • rsyarcia
      Hair Straightener Tech
      • 711
      Make it clearer my friend..
      Nobody is perfect..
      • kannuki2
        • Feb 2012
        • 398
        even paul don't recommend you to buy his service manual for your problem.
        • Iowatech
          Not a service manager
          • 3930
          I'll take a shot at this. It sounds like the problem happens in the aligning or registration roller area, what with the no print part. I'd first make sure the paper was loaded correctly in the drawers and is in good shape, and then check that the aligning or registration rollers and nearby paper guides are in good shape as well.
          Hope this isn't nonsense. Get back to us with more information and we can help you out more.
