Ricoh aficio 700
  • khaled_abosere3@yahoo.com
    Head technical support
    • Mar 2012
    • 170
    [Electrical] Ricoh aficio 700
    In my Ricoh aficio 700 was cut off power and save mode key indicator is lighting then power supply board was replaced and machine works well for 2 months after that the machine cut off power again and also save mode key indicator is lighting so we thought the problem is with power supply board which is replaced again with another board but the machine did not work we tried this last board with other machine it worked well it means that the last power supply board is work so we need a help to know where the malfunction
  • skynetto
    • Sep 2012
    • 257
    Re: Ricoh aficio 700
    Please place a full stop once in a while I was loosing my breath.
    • kannuki2
      • Feb 2012
      • 398
      Try bcu, iob, paper feed board
      • JustManuals
        • Jan 2006
        • 9838
        Paul@justmanuals.com
        • techsass
          • Dec 2010
          • 248
          Look for a 5v short. I'd check the tandem tray paper level sensors 1st.
          • Eric1968
            • 2458
            This machine is ancient and belongs in a museum.
            • fshead
              • 2376
              this makes me feel "modern" with a bunch of 1060 and 1075s..
              if i was you id pick a up a 1060 or 1075..
              cant cost more than what you will spend on time and odd parts..
                • Mar 2012
                • 170
                it is not mine it belongs client
                  • Mar 2012
                  • 170
                  I have replace the BICU board and machine is work now
