Ricoh MP 9000 Charge Corona error
  • Doug James
    • Jan 2012
    • 935
    I've replaced the pre-charge and charge corona wires and grids (with ricoh parts) still getting this error. Any help would
    be appreciated. Thanks so much
  • TonerMunkeh
    Professional Moron
    • 3865
    Re: Ricoh MP 9000 Charge Corona error
    Is there a specific SC code it's giving? You might need to change the corona units as a complete unit, the end blocks might be shorting out.
    Hit it.
    • Doug James
      • Jan 2012
      • 935
      The Sc code is SC 300. This is actually the second unit that I rebuilt. The first one threw the code, we changed the whole assembly (The grid was all funky and the corona wire was kinked up but straight). So I rebuilt the new assembly and still getting the sc300...
      • rthonpm
        • Aug 2007
        • 2847
        Check your front door switches, and also take a peek at the charge power pack.
        • Doug James
          • Jan 2012
          • 935
          Will do... Thanks so much
          • incognegro
            • Feb 2013
            • 20
            Yup, charge power pack board is the most likely culprit here.
