MPc400 Scan to USB (front)
  • MitchD
    • Oct 2012
    • 164
    The sales brochure says this model (LD130c) will scan to either USB or SD front card slot. Any idea on how to configure this? I looked through the service manual and couldn't find anything on it at all.
    "Heavy music to the normal ear is nothing but a loud annoyance. Most people think of it as obnoxious, talentless music but to someone who really listens and is really in love with music knows how beautiful and amazing it can be" Tommy Rogers of Between The Buried and Me"
  • Eric1968
    • 2458
    Re: MPc400 Scan to USB (front)
    It's all in the user manuals. In System Settings - Key Operator Tools you can switch on or off the use of the USB- and SD-Slot.
    • Aquintasii
      • Feb 2013
      • 10
      If you look on the front / right side of the operational panel and that is where you will want to insert a SD card or Thumb drive. From there you can select scanner-->Store File (At the top of the screen)-->Store to memory device-->Ok. Then you can select your scan settings as far as color and size and such.
      *Cheers
      • ruben
        The New Guy
        • Oct 2012
        • 1204
        USB support is enabled by default, if you are trying to use a USB stick or SD card and it isn't working then your stick/card is too large and cannot be read by the machine.
        • MitchD
          • Oct 2012
          • 164
          *Cheers
          That was it. Turns out I just didnt know how to do it. Thanks to everyone for the responses.
