sc982 ricoh aficio 2020
  • NOTARICOHTEK
    RIcoh af 2020 error sc982 was working ok until installed faxprint scanner module from ricoh 2015 wit ths error. Is there any way to reset this?
    thank you
  • cobiray
    Passing Duplication Xpert
    • Mar 2008
    • 1199
    The same kit was used for both models. If it's a NA machine you might try changing sp5 807 1 to 2.
    • Scott_Lewis
      • Mar 2007
      • 519
      thank you
      Were both machines set up for the same country?
      • NOTARICOHTEK
        yes they were from the same country.
        • iMind
          Vacuum Cleaning Expert
          • Mar 2008
          • 1116
          try printing smc, theres no SC982 in service manuals
          • DocF
            Old Retired IKON Drudge
            • 41
            Quoted from the FSM.
            SC982 - Localization error
            The localization settings in the nonvolatile ROM and RAM are different
            (SP5-807-1).
            First machine start after the NVRAM is replaced
            Incorrect localization setting
            Defective NVRAM
            In this case, I would lean toward the first possible cause. This is account the module had been installed in another machine.
            Doc
