nashuatec 3527td making blank copies
  • johann
    [Misc] nashuatec 3527td making blank copies
    hello
    newbie and trying to fix problems for my machines ,
    i have a nashuatec 3527td and when i tryng to make copies , always doing blank copies , i checked the toner and half full
    i tested with a copy on the scan and blank
    so 1/ I would like to know how to do a test copy for see if its the scan problem too ??? how i can do that
    2/ the drum can be the problem ? on the manual nothing at all about that , very bad SM my god , all is doing for call the technician
    have some idea about could be the problem or this copy machine is so old than better to though to the garbage
    anyway thanks so much
    everyday learning more and reading more stuffs here too for be more independant
    thanks
  • sandmanmac
    • 3981
    Re: nashuatec 3527td making blank copies
    It's a 1995 model, and it's an analog machine - not digital, so I'm not sure what you mean about "test copy" and "Scan".
    I wouldn't waste 5 minutes, or $5 on it ( and I've already wasted 2).
    • brunot
      • May 2012
      • 148
      Hi,
      You will have to test the machine with the front door open. Use a screwdriver to activate the Front Door Safety Switch. Stop the copy process(remove the screwdriver) when the paper reaches the OPC drum and check if there is an image on the drum. If no image: check the DRUM CHARGE and if there is an image,check the IMAGE TRANSFER & PAPER SEPARATION.
      Hope this help
      Bruno
