SC 670 popped up right after I have updated the following firmware:
-system/copy
-printer
-scanner
-fax
-engine
any idea on what went wrong?
First, load the system and engine firmware one at a time. Then load the rest of the firmware. Also, make sure you are loading the correct firmware for that machine, and that no firmware for other models are on the card you are using.
