c4501 yellow toner low
  • Silvertoast
    • Feb 2010
    • 270
    i have a ricoh c4501 that keeps saying yellow toner low.
    have tried
    new toners
    toner end sensor
    toner pump
    removed hoses and cleaned out
    the control board that the toner bottles come in contact with when u install the toner
    new dv unit
    updated firmware
    i can run yellow sky shots while cheating the front door and see the toner bottle turning
    i can run about 40 sky shots before it actually says toner empty. but can turn the copier off and remove the toner, turn back on and reinstall toner and itll say low again?????
    if i disable the toner end sensors (obviously) it doesnt say low toner any more just show that all toners are full
    bout to think that all that is left is the control board???
  • Iowatech
    Not a service manager
    • 3930
    Re: c4501 yellow toner low
    Um, I didn't see where you tried replacing the yellow PCU. So if you actually haven't done that, you probably should change the PCU before the control board. Maybe clean the ID sensors as well?
    If you did do that, sorry for wasting your time.
    • SargeNZ
      • May 2012
      • 263
      I thought the level on these toners was written to the RFID tag on the bottle itself. I have heard of a few early low warnings on both 01 and 02 series machines. Don't know if there is anything from Ricoh about it yet.
      • Silvertoast
        • Feb 2010
        • 270
        havent done the pcu yet. but dont see how that would cause a toner low condition (worth a try though) wasnt even recomended by ricoh tech support.
        • Silvertoast
          • Feb 2010
          • 270
          these use a toner end sensor that is just above the toner tube. i think the chip on the toner bottle just identifies the type and product code of the toner???
          • rsyarcia
            Hair Straightener Tech
            • 711
            Have you used a brand new toner pump?We haven't change boards for this problem.
            Nobody is perfect..
            • TonerMunkeh
              Professional Moron
              • 3865
              Are you using OEM toner?
              Hit it.
              • CableGuy
                Impulse Drive Engineer
                • Oct 2008
                • 417
                Print out an SMC and check the TD sensor output against the other colours. An Had you done anything to the machine prior to the message showing up?
                • Silvertoast
                  • Feb 2010
                  • 270
                  yes oem toner
                  • Silvertoast
                    • Feb 2010
                    • 270
                    checked all the yellow outputs and compared to other colors and the yellow does vary from the other colors (this was done while on ricoh tech support number)
                    that was when they told me it had to be the toner end sensor. which it wasnt. since the values were diffrent that is what led me to try a new dv unit, but no luck there either?
                    nothing was done prior to this happening
                    • Jomama46
                      • 2900
                      I had a c3501 with a constant low yellow toner also. AFter trying everything mentioned here, I did a reset with 3-045. It seem to fix the issue. It has been about 3 weeks now. Of course, now that I have cursed myself by posting this, they will call in today. When they do, I will 3-045 them again.
                      sigpic
                      A+; Network +; PDI+
                      • Silvertoast
                        • Feb 2010
                        • 270
                        update....
                        after talking with our regional ricoh rep, he said it was the nvram on the BICU pwb. fingers crossed will see. part should be in tomorrow
                        • okirob
                          • Feb 2012
                          • 26
                          there ia also a rfid board that can cause the same issue pn# is D0895177
                          • CableGuy
                            • Oct 2008
                            • 417
                            Out of interest, if you do a colour calibration and stop it before it prints to the page, what does the density look like on the ITB?
                            • Silvertoast
                              • Feb 2010
                              • 270
                              update!!! the nvram on the bicu fixed the problem. unfortunatly since the old nvram was corrupt we couldnt back it up first. so everthing had to be put back in maunally off the smc reports and the SN
