mpc2050 noise
  • xordi69
    • Jun 2010
    • 200
    mpc2050 noise
    hi
    i have a Ricoh mpc2050 using heavy A3 paper on tray 2, and makes very noise, also when paper outs from friction pad, still more noise. I will try replace frictin pad and spring, but any other idea?
    thanks
  • rsyarcia
    Hair Straightener Tech
    • 711
    Re: mpc2050 noise
    Even you replace the Friction pad and feed roller,it will be the same. You can eliminate the sound if you hold the tray while the machine is copying. So what we are doing we put a thick sticker under the tray(right side).
    Nobody is perfect..
    • CableGuy
      Impulse Drive Engineer
      • 417
      Re: mpc2050 noise
      There is a bulletin out on noise from the PCU's, which have been modified.
      • TonerMunkeh
        Professional Moron
        • 3865
        Re: mpc2050 noise
        There is a modified friction pad out for he trays which changes the urethane for cork.
        Hit it.
        • catgoldfish
          • 70
          Re: mpc2050 noise
          Do you have a part number for this? Thanks. The cork pads don't make that rubbing noise like the plastic ones.
          • Zeldaman
            • Mar 2011
            • 946
            Re: mpc2050 noise
            Hi there!
            Very interesting. In germany we'll only get the"greased" urethane-pads which are really crap, cause after ca. 20K prints there gone, producing jams.
            Greetings...
            • rsyarcia
              • 711
              Re: mpc2050 noise
              We also used the modified pad and Roller but still the same, just try to do what I've i mentioned above and you'll be happy.
              Nobody is perfect..
              • Mark Bbb
                • Jun 2012
                • 1662
                Re: mpc2050 noise
                The operation manual mention that other kind of papers mind come with a little... noise... So, don't worry, be happy.
                • Mark Bbb
                  • Jun 2012
                  • 1662
                  Re: mpc2050 noise
                  "might come"
                  • tcs04
                    FORMER Techie
                    • 1183
                    Re: mpc2050 noise
                    I've posted on this before, the new pads don't fix the problem.
                    remove the tray and look at the black plastic roller at the front of the tray runner in the machine.
                    Turn the roller, if there is a flat groove cut into the surface, that's the problem. When you push the tray in the roller rotates to the flat and then stops. This drops the corner of the tray and causes vibration.
                    You will have to replace the whole runner, but the fault will eventually return when the new roller wears out!
                    • catgoldfish
                      • 70
                      Re: mpc2050 noise
                      Part number for this please..........
                      • tcs04
                        FORMER Techie
                        • 1183
                        Re: mpc2050 noise
                        Tray 1: D0392591 guide rail right no 1: Assy (item 67 u010 paper feed)
                        tray 2: D0392595 guide rail right no 2: Assy (item 69 u010 paper feed)
                        • catgoldfish
                          • 70
                          Re: mpc2050 noise
                          Thanks for the part numbers. I assume this fix can also be applied to other Ricoh copiers with the same feed system?
                          • tcs04
                            FORMER Techie
                            • 1183
                            Re: mpc2050 noise
                            specific to the mp c2030/ 2050 and I assume later variants.
                            • benn84
                              • Jan 2011
                              • 26
                              Re: mpc2050 noise
                              hi, im having similar problem with a 'groaning' noise coming from the tray but its only on tray 3, ive had a look at tray 2 and i can see the wear marks on the black roller as mentioned but tray 3 doesnt look no where near as bad plus it is completely differnt shape to trays 1+2 would the solution be the same with swapping the rail? (D3311103 Supporter:right:assy)
                              Ben
