Ricoh 3235c B&W shaded,Collor ok
  • Herostrat
    • Oct 2012
    • 220
    Anyone encountered this on collor machines?
    If only black is printed then letters are slightly shifted,like they are shaded,for example letter A has another A less than one milimeter behind it and it's a bit pale.
    If print has collor...any collor,for example a yellow dot on top of papper then ewery black letter is fine without shade.
    Makes me think that drive motor for black PCU is weak and works fine when collor drive motors works with him.
    I'll go there again and try SP5-993-007...not shure what to expect but meybe Line Position Adjustment will show me something.
    Gears,springs,clutches,sliders,connectors and electronics...who on earth can tell what's wrong with it?
  • JustManuals
    • Jan 2006
    • 9838
    Re: Ricoh 3235c B&W shaded,Collor ok
    Paul@justmanuals.com
    • Herostrat
      • Oct 2012
      • 220
      Well,SP code showed nothing and changing black drive motor solved nothing...
      • sandmanmac
        • 3981
        "A picture is worth a thousand words".
        I think a few image samples would be very helpful to understand exactly what you mean
        • Herostrat
          • Oct 2012
          • 220
          Indeed I shuld have posted some pic's,yed I had no time recently.
          In the meantime we fixed it back in service,it was laser assembly,K-LD unit actualy and the dual beam mechanism.
          The second beam wasn't high enough bcs it's drive motor was failing.
