SP C320DN ERROR 5403?
  • STRAYCATZ
    • Aug 2025
    [Error Code] SP C320DN ERROR 5403?
    Anyone have info on this code?
  • HP:guy
    • Feb 2013
    • 279
    Re: SP C320DN ERROR 5403?
    No such code Please confirm.
    • STRAYCATZ
      Ya, sorry, went to site. Code is sc543. Fuser problem
      • JustManuals
        • Jan 2006
        • 9838
        Paul@justmanuals.com
        • CableGuy
          Impulse Drive Engineer
          • Oct 2008
          • 417
          Time to buy a maintenance kit, part number will be in the manual you buy from Paul.... (Do I get commision for this?)
          • STRAYCATZ
            I was able to figure out how to reset fuser code, machine is working fine! and I have bought manauls from Paul before.
            • copimen
              • Aug 2013
              • 8
              How did u reset the code coz mine doesn't want to reset same machine same problem
              • JustManuals
                • Jan 2006
                • 9838
                • sandmanmac
                  • 3981
                  Then you have an actual fuser problem. install a maintenance kit, and reset code again
                  • Iowatech
                    Not a service manager
                    • 3930
                    Two things:
                    First of all, you might want to get a maintenance kit handy anyway, because sometimes the sensors that cause SC543 are almost worn out, but not totally. So resetting the code will get you by for a while, but the error code will come back soon. I'm pretty sure there is nothing in the maintenance kit that wears out over time, and you will need one eventually.
                    Second, if you get the maintenance kit, but you don't need to use it for quite a while, you should probably keep an eye on local events that affect the power supply coming from your local power utility, as if that voltage changes beyond specifications it can cause all manner of improper machine operation. While they won't eliminate this problem completely, surge suppressors or line conditioners will reduce the chances of that.
                    • copimen
                      • Aug 2013
                      • 8
                      Iowatech thanks a lots, I changed the Power Supply now my machine I working thanks a lot Guys.
                      • bjakobs
                        • Mar 2010
                        • 25
                        Also, there is a engine firmware update which has sorted out this error for me multiple times.
                        01.07 Symptom corrected:
                        1. Fusing control was modified to further improve the detection accuracy of SC543.
                        Note: With the previous version (v01.06 or before), the fusing end thermistor sometimes triggered this SC unnecessarily, in between the Ready condition and beginning of a job.
