mpc 7500 light copies
  • T911
    • Jun 2007
    • 628
    I'm getting light copies in black. I rebuilt the black pcu with drum blades wax cw's developer. Bias plates on pcu are all in place. It' not bold enough on the print side and if I make a copy of the print it gets lighter. So I have to bold up the print and I'm hoping its a sp setting for the scanner. Optics and lasers r clean too. Help appreciated. Thanks
  • Horologydoc
    • Jun 2011
    • 61
    Re: mpc 7500 light copies
    Make sure your firmware is 1.06:06 or newer. Check your sp3561 and make sure it's 8.5% or higher. If it is run image density correction under manual procon and then run full music. If it's below 8.5% you have an issue with your toner concentration in your developer. Run sky shots/ manually add toner until sp3561 is at the correct level.
    • T911
      • Jun 2007
      • 628
      thanks much, i will look into it.
