MP C2500 Color lines
  • llyyhh
    • Mar 2013
    • 9
    Hi everyone,
    Came across this issue with MP C2500-Color lines all over the page when copy/print with full color mode,but was alright in B&W mode.(Please refer to attach file)
    Replaced all PCU still same issue.Quite sure was not problem with optic/scanner.Could it be the Laser unit issue?Any advise is much appreciated.Thanks in advance.
  • JustManuals
    • Jan 2006
    • 9838
    Re: MP C2500 Color lines
    Paul@justmanuals.com
    • Eric1968
      • 2458
      Transfer Belt Cleaning Unit? At the top of the page you also see some black spots. If you replaced all the PCU's, the next suspect would be the Cleaning Unit.
      • llyyhh
        • Mar 2013
        • 9
        Have checked & vacuum the Transfer Belt Cleaning Unit,it's in great condition.Would try the Laser unit next Monday.
        • rsyarcia
          Hair Straightener Tech
          • 711
          Clean the PCU especially the charge rollers
          Nobody is perfect..
          • Eric1968
            • 2458
            The Cleaning Units lasts for 160k. Even if it looks ok, it can still cause lines/streaks. I'm almost 100% sure this isn't a Laser Unit problem.
            • llyyhh
              • Mar 2013
              • 9
              I can confirm is NOT PCU problem coz I swap with my other MPC2500 and they work fine.Any other suggestions?
              • andy227
                • Jan 2013
                • 219
                Same here. Simply looking at it and it looks ok is not good enough. Also check the fuser cleaning roller and oiling roller. The cleaning roller on these tends to get really clogged up with toner and then offsets it back on copies in exactly the same way as your samples. Had it many times, need to clean it regularly and change the oiling roller.
                • llyyhh
                  • Mar 2013
                  • 9
                  Problem rectified.The Blue & Magenta DU connectors(machine part) went wrong.I pull & insert the DUs few times & bingo!
                  Thanks for all the replies.
                  • CableGuy
                    Impulse Drive Engineer
                    • Oct 2008
                    • 417
                    I'm willing to bet a few bob that this one comes back. In cold weather these things can give you these lines and then disappear, especially when the PCU has a few miles on the clock. If it's around 100% replace the PCU, otherwise you be back there next week changing it anyway....
                    • Morty
                      • Jan 2012
                      • 5
                      Try changing the values in SP 3 241 nr 5-6-7-8 from 140 v to 180v this does the trick , I am doing this to all my machines . with a service . ageement .
