SC670 After Firmware upgrade
  • daveyball
    • May 2009
    • 314
    I have a Ricoh MP2851, that we needed to upgrade the firmware on. After doing so the machine gave us SC670. Tried unplugging HDD etc. We spoke to Ricoh Tech support who said to replace the NVRAM chips. We have done so, and we still have the issue. The are now saying replace the BCU, and then the controller if that doesn't work. Is there anything else I should be looking at, before going down this route. Thanks in advance
  • TonerMunkeh
    Professional Moron
    • 3873
    Re: SC670 After Firmware upgrade
    If you pull the controller and set dip switch 1 to OFF, the machine will boot from the SD card. Put the system / copy and engine firmware on the card and get the machine to try and boot from it, hopefully that should sort you out.
    Hit it.
    • JustManuals
      • Jan 2006
      • 9919
      Paul@justmanuals.com
      • Eric1968
        • 2459
        When replacing the NVRAM, you should first backup the old NVRAM contents to an SD-Card (if possible). Replace the NVRAM, then do a Memory All Clear (SP5-801-001) and then reload the NVRAM Settings from the SD-Card to the new NVRAM.
        • daveyball
          • May 2009
          • 314
          Tried as suggested now getting SC672, Controller to ops panel communication failure, any ideas?
          • TonerMunkeh
            Professional Moron
            • 3873
            Disconnect the hard disk and see if the code disappears. If not, put the old nvrams back in and try the same SD card boot trick again. If not, it sounds more like either the controller has had it or the BICU nvram has also failed, possibly due to a corrupt firmware file.
            Hit it.
            • katash
              • May 2010
              • 221
              i changed the bcu and sorted the issue
