SC 322 (Aficio 2045)
  • sharpmind
    • Sep 2009
    • 478
    Problem with the laser scanning unit. Already replaced the laser diode unit and performed laser beam pitch adjustment but still SC 322 shows. Any idea to rectify the problem?Replacing the whole laser scanning unit is a good solution but not a good idea because it is expensive. Two machines have the same problem.
  • vargue
    • Oct 2011
    • 404
    Re: SC 322 (Aficio 2045)
    ribbon cable
    • fbkhan3
      • May 2012
      • 421
      Sometimes replacing the door switches sorted it out for me,specially the one for right door above the fuser Unit.
      hope that helps!
      • sharpmind
        • Sep 2009
        • 478
        hope that helps!
        I just want to correct myself. It is not Aficio 2045 but rather Aficio 3045. Actually, the machine was working before. My colleague removed the whole LSU assembly and installed it in other machine sometime ago.
        He returned the defective LSU and installed it back to the machine. The machine is now having SC 322. My boss wants me to fix the problem. I already replaced the LD unit and performed the calibration but still an error.Connectors are good.
        • rsyarcia
          Hair Straightener Tech
          • 711
          Hello Mr.sharp check the threads about SC 322. Agree with fbkhan.
          Nobody is perfect..
          • sharpmind
            • Sep 2009
            • 478
            If there is no problem in the LSU, then why it shows same error SC 322 when I installed or swap it the working machine?Meaning, the problem is only in LSU and not in the door switch.
            • fbkhan3
              • May 2012
              • 421
              To make sure check this laser on a working machine.
              If this Unit (LSU) is working in other machine as you said,then you gotta be looking somewhere else,not the Laser,it starts from cables to the controller.door switches,PSU.
              good luck!
              • rsyarcia
                • 711
                [QUOTE=sharpmind;348185]If there is no problem in the LSU, then why it shows same error SC 322 when I installed or swap it the working machine?Meaning, the problem is only in LSU and not in the
                Ahh.. Ok so you tested the LSU On a working machine. That's fine.
                Nobody is perfect..
                • ali.alhaj
                  • Mar 2013
                  • 34
                  hi
                  do LD Beam Pitch Adjustment for
                  400dpi -----144
                  600dpi------168
                  with best regards
                  • rsyarcia
                    • 711
                    Originally posted by ali.alhaj
                    hi
                    400dpi -----144
                    600dpi------168
                    with best regards
                    Read his post and he did what you are telling.
                    Nobody is perfect..
                    • Drummer
                      • Feb 2013
                      • 46
                      Have you tried ( prying up on the laser section with a striaght screwdriver just under the mounting screw ) while tightening the mounting screws? I believe there was a bulliten on the older models for the machines that have laser codes. The window for the laser section was obstructing laser causing codes, and lifting the laser section cured the problems.
                      Hope this makes sense, typing instructions was never my strong point.
                      • gernah
                        • Jun 2009
                        • 57
                        [QUOTE=sharpmind;348166]Problem with the laser scanning unit. Already replaced the laser diode unit and performed laser beam pitch adjustment but still SC 322 shows. Any idea to rectify the problem?Replacing the whole laser scanning unit is a good solution but not a good idea because it is expensive. Two machines have the same problem.[
                        Dear Sir,
                        Regarding with your problem I can help with you very simple remove the lsu and clean properly all mirrors big and small but make it sure when you return it back.the mirror will be the same position.100% you well be happy the result.have a nice day!!!!!goodluck
                        • kannuki2
                          • Feb 2012
                          • 398
                          You might have bad bicu if laser diode and motor replaced.
