SC 542 Ricoh Aficio 1027-1022.....t
  • issahodeh
    • Jun 2007
    • 22
    I have many of this model most of them are the same the Sc 542 just at the morning but after the user clear it by C 107 C sp On/Off. the machines works allthe day with no problem just at the morning.
    I replaced the thermistors and the thermofuse.
    Please advice
  • scully
    • Mar 2006
    • 46
    Look at the siting of the machine and the environment as this is a probable cause as first thing in morning !Try running The fuser temp in 105-9 at a value of 90 rather than default of 60 this means it will run at 10dgrs higher for 90 secs on start up rather than 60 secs.Worth a try ?JohnUk
    • cobiray
      Passing Duplication Xpert
      • Mar 2008
      • 1199
      We've had some of these issues also, all in colder months. Some places cut the heat back at night and the machine cools to that temp, preventing it from warming up in time.
      Also check the thermistors for build up and hot roller for wear.
      • kyoceran
        • 100
        sc542
        turn fusing idle on, and if possible extend the warm up time.Might also need firmware upgrade.
        • Star
          Ricoh Tech
          • 127
          Upgrade SBCU firmware to ver 3.23 or newer, and set SP1103 to 2.
          • Codex
            • May 2008
            • 694
            Hello
            We had the same problem but only with non original Fusing Roller, and normally only on Lanier machines.With original Ricoh parts we had no problem.
            Memento Audere Semper
            • laktech
              • Jun 2007
              • 17
              how many fusing lamp its use? if two, you can check again them and AC drive board.
