Reco FT4015
  • cliffhangers
    • Feb 2010
    • 242
    Reco FT4015
    good day,please i need help on this RecoFT4015,it's copying blank page and the whole pepper is very dark,i don't know what to do i have check the corona wire and cleaning blade all is good bet the copier still copy blank with the full page very black,any one who have had this problem and solved it should kindly help me.THANKS IN ADVANCE.
  • JustManuals
    • Jan 2006
    • 9838
    Re: Reco FT4015
    Paul@justmanuals.com
    • Eric1968
      • 2458
      Re: Reco FT4015
      If you're sure that drum/dv-unit are ok, then it could be a mirror problem, or maybe the lamp voltage is not correct.
      BTW, this machine is over 15 years old and it belongs in a museum...
      • sandmanmac
        • 3979
        Re: Reco FT4015
        Agreed. Time to put this old dog into retirement!
        Could be mirror position, otherwise likely a PCU shorting issue..
        Did this issue just "happen" or did it occur after a service procedure you did?
        On a side note....Is this "International FT series day" or something? This is the 2nd post today about one of these
        • daveyball
          • May 2009
          • 314
          Re: Reco FT4015
          Check transfer stop the copy half way and see if the image on the drum.
          i.ve answered both today's post on the ft range, I,m showing my age
          • bat
            • Sep 2008
            • 140
            Re: Reco FT4015
            Check drum grounding...
