When (not) to update firmware?
  • skinnyb
    • 291
    Re: When (not) to update firmware?
    Unless firmware is documented to fix a particular problem, I don't touch it. Even if getting tech support involved (which I rarely do). If tech support asks if firmware is up to date the answer is always Yep!
    • Exok
      • Jun 2011
      • 750
      In my 20+ years of servicing Savin/Ricoh I've only felt the need to update software when the machine had a software corruption. In my experience, those problems were few and far between. I've had many machines go 10+ years on the original software without a need for an upgrade.
      • M0scb
        • Oct 2012
        • 32
        I update firmware on most of my calls. In the last 10 years, I have only ever killed 2 machines, one was due to a faulty controller board. There are some firmware fixes that can prevent a subsequent issue generating another call. I find upgrading everything , not just engine and system seems to help. The only time I leave well alone is when custom firmware has been installed. It is just down to personal opinion.
        • KenB
          Geek Extraordinaire
          • Dec 2007
          • 3944
          #19
          It's bad medicine to "pick and choose" which updates to do, regardless of brand.
          A version of main controller will require a certain version of NIB, printer, etc...
          Not keeping all parts of the machine at the same "level" can be one reason why so many techs shy away from it, thinking they will break something. The truth is, if you don't do it all, you just very well may.
          I remember some years ago on Canon machines our configuration centers were flashing iR3570s and the like with main controller firmware, but little else. When the machines hit the customers' offices, the RUI (web page) would fail to open. After a few of these, it was easy to see the problem.
          The way I see it, engineers (I know, I already hear snickers) get paid big bucks to write this stuff. I would think (or at least hope) there is reason for it.
          • Dumus
            • Feb 2010
            • 79
            #20
            What would our old proverb says:
            Feed the chickens and do not touch the buttons.
            Or, in translation, if and only if it is not you do make it to work.
            • mikadonovan
              • May 2008
              • 2931
              #21
              I'm guessing with that philosiphy doing pm's is a total waste of time.
              NEVER ASSUME ANYTHING
              • Cipher
                It's not easy being green
                • May 2006
                • 1309
                #22
                It's fairly important to keep your machines up to date as a broad range of issues are being fixed via software these days.
                Some general tips.
                1. Read the readme files they may contain warnings / additional instructions.
                2. Read the readme files they may contain warnings / additional instructions.
                3. Don't update anything that displays a completely different firmware number from the older version.
                4. Always update all the modules.
                Some fixes are dependant on one or more modules being updated to the latest versions.
                I would recommend excluding Java updates though, best to leave those to the solution boys to sort out.
                5. On the older models (DSc) and smaller models (MP 161/171/201) the safest way to update is to do the system/copy first on it's own and to do network support on it's own.
                • Lagonda
                  • Aug 2008
                  • 1649
                  #23
                  I'm another one firmly in the "if it aint broke, dont fix it" camp. I've had too many dramas over the years where the update didn't go smoothly and you spent the rest of the day trying to coax the beast back to life. Also if you take the time to read the info sheet that is released with the frimware a lot of the changes are to fix very minor and trivial problems, ie a spelling mistake in Serbo-Croat.
                  • SargeNZ
                    • May 2012
                    • 263
                    #24
                    I just bricked a Ricoh MP201 today after doing a firmware update. My own stupid fault too since it is well documented that there are two different machine versions out there, and different firmware is required to suit. So I spent 2 hours installing a temporary machine, since the BICU boards are on backorder!
