Was getting an SC 541 fusing lamp error. I found the lamp broke and used a lamp from a MP w2400 we here as a parts machine. Then got a SC541-1. Replaced the thermistor - no go still get code 541-1.
I tried something different here - I had a fuser unit like brand new only 1900 sq. ft. on it from a mp w2400 (replaced the 240w in Rioch product cycle) and put it in a 240w. I found it didn't seem to fit so I put the fuser rollers in the 240w frame.
I also had a crack in the exit door so I took the paper exit door and exit paper unit from the mp w2400 - I have all the connectors from the exit door matching up. But could it be something is different in the wiring for the mp w2400 and 240w paper exit door/exit unit that is causing this code out?
I am stumped any help or tips appreciated.
