Savin 4018d skewing
  • rdyjnkns
    • 135
    Savin 4018d skewing
    I am working on a Savin 4018d that has a skewing problem from all 4 paper trays. I believe it has to do with the registration roller which is the only thing that they have in common. However I am open to suggestions. And yes I tried to manually adjust the laser assembly, but that did not help.
    Thanks for the assists
    V/R
    Rudy
  • sandmanmac
    • 3979
    Re: Savin 4018d skewing
    V/R
    Rudy
    I believe that you're right. In fact, if you simply look at the rollers, you'll see there is virtually zero contact between the upper and lower on the front, due to a broken front bushing
    • copysys
      • Aug 2008
      • 41
      There's a tension bushing on the registration roller on the front side of the machine that breaks....check that
      • sandmanmac
        • 3979
        Exactly what I said. It would be interesting to have an update from the poster as to how it worked out though
