1357ex 109 jams
  • Wishbone
    • 100
    1357ex 109 jams
    Replace the first 2 entrance sensors in the finisher, no motors are stalling. Pretty random but jams with this code 3-7 times per day. Any ideas?
  • JustManuals
    • Jan 2006
    • 9838
    Re: 1357ex 109 jams
    Paul@justmanuals.com
    • Wishbone
      • 100
      Re: 1357ex 109 jams
      I'm an 18 year Ricoh tech. I have every manual know to man. I've been through the manuals, gooses, and trouble shooting guides. But thanks for your input.
      • Imprestik
        • Aug 2012
        • 297
        Re: 1357ex 109 jams
        This jam related to the drive on the pre stack rollers (in the R4 to R6) gates.
        What you need to do is remove the finisher control board. Behind the board there is your pre stack drive gear (1 way bearing driven by a belt)
        That bearing is slipping on the drive rollers causing your jams, Remove the bearing, sand down the shaft as it will be quite polished and reassemble.
        • Wishbone
          • 100
          Re: 1357ex 109 jams
          Now theres something I can sink my teeth into. Thanks, I will give that try on Monday.
          • CableGuy
            Impulse Drive Engineer
            • Oct 2008
            • 417
            Re: 1357ex 109 jams
            Hi
            Before you go changing a whole lot of stuff, have a look at the finisher. The 3 black guide plates where the paper collects before loading into the staple tray (page 32 in the sr5000 parts manual). I have one that the middle guide plate doesn't sit properly on it's top magnet. This will either cause the lead corner of the paper to curl or jam up. I've trained to customer to look for this when the problem occurs, they've been happy with that for the last 3 years
            Good luck
