Aficio MP 4000 copier
  • RonMac
    • Oct 2008
    • 57
    How do I reset the cleaning web on this copier? Any help appreciated. Thanks. Ron
  • fbkhan3
    • May 2012
    • 421
    Re: Aficio MP 4000 copier
    1902-1 to 0 then SP 7806-008.Execute and then RTFM.
    HTH.
    • RonMac
      • Oct 2008
      • 57
      HTH.
      Thank you. I will try that. Ron
      • copycart
        • May 2009
        • 97
        Re: Aficio MP 4000 web counter reset
        I tried resetting the web counter with 7806-8 with no success. 1903-1 is set to 0
          • 37641
          If you have the original service manual, it does not give all the SPs that need to be reset. The latest edition does.
          • Debs1964
            • Oct 2010
            • 1693
            Reset SP7-804-005 then reboot, that is all that is needed
            There are 10 types of people in this world, those who understand binary maths and those who don't
              • 37641
              7804-005 Resets the PM counter, count shown with 7803-005
              7806-008 Clears the parts counter, web parts count 7806-019
              1902-001 shows the % used. If the machine has already locked out, such as do to the belt running completely out or the switch being bad, to where it cannot be used, the last thing to do before cycling power on the machine is to enter 0 in 1902-001, even if it is already 0.
              • MCC-support
                • Jul 2014
                • 38
                If the machine is showing the web is finished even after those SP modes are done, check the web end sensor flag on the fuser to see if it is set correctly and not broken. Common issue as the flags are made of plastic.
