ricoh mpc2050 sc997
  • tullio
    • Feb 2012
    • 268
    ricoh mpc2050 sc997
    ricoh mpc 2050, error sc997 ???????????
    thanks
  • muthuk7
    • Aug 2010
    • 57
    Re: ricoh mpc2050 sc997
    Hi dear ,
    Have u updated the firmware... and which kind of extended feature options are you using.. if you could explain brief i will try to help u
    • gasino
      • Mar 2013
      • 8
      thanks
      Application function selection error
      The application selected by the operation panel key does not start or ends abnormally.
      Software (including the software configuration) defective
      An option required by the application (RAM, DIMM, board) is not installed
      Nesting of the fax group addresses is too complicated
      1. Check the devices necessary for the application program. If necessary devices have not been installed, install them.
      2. Check that application programs are correctly configured.
      • JustManuals
        • Jan 2006
        • 9838
        Paul@justmanuals.com
