Ricoh MP 4500 dirty copies
  • aikens
    • Oct 2011
    • 16
    We had 4 Ricoh MP 4500 come in off a maintenance lease. All have the same problem, dirty copies. A light toner, greyness over the entire copy. When you first run a copy it looks okay but when you look closer or compare to the original you see it. I also ran the copy count print and the result is the same so it is not in the optics (glass or mirrors).
    What I found was unusual is that all machines have very low counts ranging from 36,000 to 91,000 copies. Normally with higher count I would say replace drum and developer but with 36,000 copies?
    I have cleaned the machine including the mag roller and changed the dev bias to 660, dev bias for ID to 500 and increased charge roller bias, no change.
    I know these machines can be problematic, but looking for ideas.
    I'll keep playing with the machines when time permits and post the results if I find anything interesting.
    Thank you
  • TonerMunkeh
    Professional Moron
    • 3865
    Re: Ricoh MP 4500 dirty copies
    You're bang on with the developer. If the machine is only on 36k, it's probably on the original bag and will need to be replaced. Nature of the beast unfortunately. When you got them back, did they have OEM or compatible toner in them? Compatible probably hasn't done them any favours if it was being used.
    Hit it.
    • rthonpm
      • Aug 2007
      • 2860
      Make sure all of the machines are using the newer style toner. If there's any of the old stuff in them it will be worth it to just dump the developer, clean the mag roller, and go on with life instead of having to clean up the residual mess left by the older toner.
      • aikens
        • Oct 2011
        • 16
        Thank you TonerMunkeh;
        OEM toner in all machines, they were maintenance leases so they should have always used OEM.
        • aikens
          • Oct 2011
          • 16
          Thank you rthonpm;
          Di you mean the newer style developer??? Is there a new toner??
          Can I get away with just cleaning the mag roller or replace? I read about techs cleaning with RainX, I assume it helps prevent developer from sticking?
          • rthonpm
            • Aug 2007
            • 2860
            The toner for the MP 4500 and MP 4000/5000 series was changed a few years ago (Type 4500A). The original stuff helped to kill copy quality, though it showed up more on the 4000/5000 family, any time I did a toner change to the new stuff I always did a dev change no matter what the count was. Take a look at TSB 7R for the 4000/5000 series.
            • aikens
              • Oct 2011
              • 16
              I'll check out that TSB. Thanks
              They all have 4500A toner, I'll change the developer and go from there.
              Thanks again.
              • Ollie1981
                Toner Monkey
                • Mar 2008
                • 417
                Clean the mag roller, replace the dev. You probably won't even have to touch anything in the drum unit but if you want a belt and braces approach, clean the charge roller and vac off the cleaning brush.
                I've seen this symptom on machines that have gone barely 20k after a full PCU rebuild. Granted that was much more common on the original toner but hey.
                My recommendation though is if you are putting these machines back out to clients (or are running them yourselves) is to change the toner bottle motor for one out of a 3045, dump the dev and vac out the hopper and PCU recycle coils, refill the dev units with 3045 developer (B079 9640) and run them on 3045 toner and you will NEVER see this problem again.
                • aikens
                  • Oct 2011
                  • 16
                  How do I know if we have the updated developer? Do I just assume what we have in stock is correct part number B296-9640.
                  I just cleaned the mag roller on the unit with 36,000 and it was fairly clean no residue stuck to the roller it just wiped off. the Unit with 91,000 was harder to clean.
                  I'll vac out the developer and install new and see what happens.
                  One note, on the TSB that rthonpm suggested they state that if using the new style toner the dev bias should be 560, dev bias for ID = 400. I had set them at 660 and 500 as stated in other posts on this site. What do you think?
                  • M0scb
                    • Oct 2012
                    • 32
                    The developer was not the problem. There was too much wax in the toner, hence the MP4500"A" to indicate the modified less wax bottles. Usually once the machine was on the new bottles and a developer replacement was performed they would run cleaner. Are you putting paper between the hopper and the pcu when you set the dev up? If this is not blocked while set up is running, more toner is added to the dev unit causing it to over tone. I found this does make a difference when I had the issue.
                    • Imprestik
                      • Aug 2012
                      • 297
                      The easiest fix for these machines is to go back to the 1035/1045 dev (type 18)
                      The dev works perfectly with they toner type 4500A and the mag roller never gets build up on it.
                      I have been doing this for 2.5 years now with no issue at all and the devices have been going to 150K with no sign of copy quality at all.
                      • Jimbo1
                        • Mar 2008
                        • 845
                        Originally posted by aikens
                        Thank you rthonpm;
                        I have never used any kind of solvent on a mag roller. Just scrub with your cleaning rags or paper towels. You might LIGHTLY scrub with a scotch brite pad but that can be perilous if you get to aggressive.
                        "Some days you get the bear, some days the bear gets you."
                        Cdr. William Riker
                        • flo
                          Engineer
                          • Mar 2009
                          • 44
                          The corect Toner to solve problems is Type 4500E it is standard for ffollow up modells change the order number for this machines and it will help u
                          • Iowatech
                            Not a service manager
                            • 3930
                            Actually, if you can find "Mr. Clean Magic Eraser" brand sponges, you might try using them to clean mag rollers. They have worked well for us for a while. And they are useful for cleaning up other stuff as well.
                            On the other hand, is there any chance this is a drum ground problem? That's caused me grief like this a few times, although not on this model.
                            • Oze
                              Ricoh Fanboy
                              • Jul 2008
                              • 1663
                              Just further to this discussion...we've been modding and fitting the SP 8200A printer PCDU to this range of m/c without issue....bugger rebuilding those dirty pieces of shite..!!!
                              You just swap the front plates of the unit over...dump the contents of the pre-loaded dev capsule into the dev unit and away you go.
                              As per usual the price difference between printer unit vs rebuild is negligible and the time factor is about half.
