MP2550...Looking for small fan PN: AX64 0179
  • Foo
    • Nov 2009
    • 199
    The small fan behind the left side cover on the MP2550 I'm working on is making a little too much noise
    and I would like to replace it as a preventative measure.
    While there today I took it out and removed the label on the fan shaft and put a drop of lube in there to lube the open faced bearing and it did not.
    Sounds to me like the bearings are failing.
    PN: AX64 0179 is out of stock at Precision roller but I like to source a couple of places to make sure I get decent pricing anyway.
    Anyone have a second source for this little 24v 2.4watt fan?
    Or a down machine to pull and sell the part?
    Jeff D.
    STL
  • sandmanmac
    • 3981
    Re: MP2550...Looking for small fan PN: AX64 0179
    Not knowing the exact fan, it must be a common one. Just make note of the Amps, and air flow direction.
    I bet you have a bunch of compatible ones lying around on a shelf or in other machines. Just replace the connector if need be
