ricoh aficio c3235
  • khaled_abosere3@yahoo.com
    Head technical support
    • Mar 2012
    • 171
    ricoh aficio c3235
    My photocopier has (left) side is lighter than another (right) side just with cyan color and when I do autocolor calibration lcd display (cannot do autocolor calibration).
    with bset regard
  • banginbishop
    grumpy old git
    • Oct 2007
    • 894
    Re: ricoh aficio c3235
    pm counts for drum, devs etc?
    Incontinentia Buttocks
      • Mar 2012
      • 171
      I have replace the drum and developer with new
      • JustManuals
        • Jan 2006
        • 9838
        Paul@justmanuals.com
        • Herostrat
          • Oct 2012
          • 220
          Cleaned laser shaft?
          Gears,springs,clutches,sliders,connectors and electronics...who on earth can tell what's wrong with it?
            • Mar 2012
            • 171
            I did but there is no any response
            • banginbishop
              grumpy old git
              • Oct 2007
              • 894
              cleaned ID sensors? whats the vsg readings? smc print out done?
              • Eric1968
                • 2458
                This can can be anything... Bad Drums, DV-Units, Bad Transfer Belt, dirty Polygon Motor. You have to provide more info on this.
                • Herostrat
                  • Oct 2012
                  • 220
                  Indeed we need more info on this,I'd start from the begining...the laser assembly,inspect and clean...sometimes it's not only shaft but mirors inside.
                  Try scaning test print and post it here.
                  • Imprestik
                    • Aug 2012
                    • 297
                    Sounds like the cyan dev clutch has crapped it's self
                    common problem on these machines
                    replace all 4 dev clutches at once and make your life easier
