Ricoh 3245c Copy quality poor
  • qwandy
    • Mar 2013
    • 38
    Hi
    I have a 3245c that prints very well, but the photocopy of the same document is very poor, bad colours etc, and very faint.
    Any help please
    Andy
  • rsyarcia
    Hair Straightener Tech
    • 711
    Re: Ricoh 3245c Copy quality poor
    clean optics first..
    Nobody is perfect..
    • qwandy
      • Mar 2013
      • 38
      Thanks, new to this machine, can you point me to them? Are they above the developers?
      Andy
      • JustManuals
        • Jan 2006
        • 9838
        Paul@justmanuals.com
        • rsyarcia
          • 711
          Andy
          If you are not familiar to this machine it is better to have a service manual. Nonetheless, you can see the mirrors under the platen glass(under your adf unit).
          Nobody is perfect..
          • Eric1968
            • 2458
            If you're not able to find the optics you're obviously not a tech. I suggest you call one.
            • qwandy
              • Mar 2013
              • 38
              I am trying to learn with a machine of my own and not doing any harm to anybody, but thanks for your blunt reply.. very helpful.. I did think that somebody would be happy to share their experience.. obviously a closed shop and I do apologise I was expecting somebody helpful...
              • Eric1968
                • 2458
                I'm sorry if it sounds a bit blunt, but if you don't know what you're doing with the optics you can cause serious harm to this machine. I've seen techs taking the Lens Assembly apart and complaining about Service Calls and black copies. If you carefully clean all mirrors and scanning lamp you'll be fine.
                • Iowatech
                  Not a service manager
                  • 3930
                  If you can, check out the archives here. There's loads of information there that can help, if you want it to.
                  • sandmanmac
                    • 3981
                    It could simply be that the default copy setting is "photo" or at least something other than “text” which will provide a lighter image.
                    I do agree that if the term “optics” is over your head, you`ll inevitably do far more harm than good, if you start trying to do maintenance on this machine.
                    • Exok
                      • Jun 2011
                      • 750
                      My suggestion would be to search You Tube for videos of basic copier maintenance and Cleaning Optics on Copy Machines first before starting your DIY project.
                      Best of luck. Report back when you succeed or run into a new problem.
                      • qwandy
                        • Mar 2013
                        • 38
                        Thanks but like I said just trying to learn so it does not matter if I mess up my own machine does it?
                        Andy
                        • tufbnme
                          • 493
                          Sent you a PM, check your email
                          • qwandy
                            • Mar 2013
                            • 38
                            Many thanks
                            Andy
                            • knightfall
                              • Jul 2006
                              • 633
                              you have every right to learn your machine but also realize this is an electromechanical device which reproduce images using high voltages, your best bet to stay alive and not get yourself or anyone else electrocuted is to buy a service manual from paul@justmanuals.com read the manual on how to get to certain parts recommend here. There are things you should never touch that could make it a hazard for you or anyone who uses the copier.
                              good luck
                              Get your facts first, and then you can distort them as much as you please.
