MP 5001
  • Kopytek
    • Jun 2025
    [Misc] MP 5001
    Print becomes lighter even after replacing dev unit , pcu assy , and dev material .
    checked grounds and still gets lighter over time .
  • Zeldaman
    • Mar 2011
    • 946
    Re: MP 5001
    Hi there!
    Dissasemble the tonerhopper, i bet that the mylar-flippers are loose !
    Greetings...
    • Kopytek
      Re: MP 5001
      Originally posted by Zeldaman
      Hi there!
      Greetings...
      Thanks for the feedback ...the toner hopper was replaced also with a new one .
      • TonerMunkeh
        Professional Moron
        • 3865
        Re: MP 5001
        Are you using OEM toner? Can you turn the bottle motor in output mode?
        Hit it.
        • Kopytek
          Re: MP 5001
          Hello..Thanks again for feedback . The machine is using Ricoh toner for that model...the toner motor is my next part to replace although it does turn in the output mode and seems to be adding toner .
          • JustManuals
            • Jan 2006
            • 9838
            Re: MP 5001
            Paul@justmanuals.com
            • collme
              Ricoh tech
              • 221
              Re: MP 5001
              Check ID sensor as well. if coated in toner so only see's black when reading drum patch it will think it is toned ok and not add toner.
              • Kopytek
                Re: MP 5001
                Thanks...the sensor was checked and cleaned ...perhaps it is marginal ....will look into it more .
                • Polarbear
                  • Feb 2012
                  • 1070
                  Re: MP 5001
                  Is the drum OEM? We had huge problems with light copies because of compatibles (Katun).
                  We reverted back to OEM and all the problems went away!
                  Press the GREEN button!!
