Scan useing windows 8
  • geardriven
    • May 2008
    • 32
    Hi Guys,
    I have a MP C3000 /4500 that I am having problem with SMB scan with windows 8 i read that it needs new firmware. I am not sure any help would be appreciated.
  • ruben
    The New Guy
    • Oct 2012
    • 1203
    Re: Scan useing windows 8
    You need at least version 9.66 of Network Support firmware (and possible System as well) to scan to Windows 8.
    See also: RD081005j.doc
    Best to update all the firmware to the latest level in one go.
    • mikedci
      • Jul 2010
      • 227
      see also also...
      • geardriven
        • May 2008
        • 32
        I was afraid of that. does anyone have access to the latest MP C3000 firmware?
          • 36827
          Go to TSRC. In the B230/B237/D042 Tech tool Box, click on Special/Custom Firmware. Download either the SD card or Remote version posted on 2/6/2013. I just did a Lanier LD420c today. Worked great.
            • 36827
            My previous reply is for the MP C3000. The MP C4500 would be B222/B224. You still have to download the custom firmware.
              • 36827
              The two attached zip files are for the C3000.
              • accelinet
                • 1
                Thank you, slimslob! Worked perfectly on a 2500.
                • randula7
                  • 73
                  IS this working with mpc 4500 & 3500????
                  • ruben
                    The New Guy
                    • Oct 2012
                    • 1203
                    No, set up scan to FTP or email; then never worry about it ever again, forever.
                      • 36827
                      Ricoh released a custom firmware on 1/11/13. Login in to TSRC, select Color MFP, Select B222/B224, then click on the "Special/Custom Firmware"
                      • Dexor
                        • 223
                        Upgraded to the latest firmware - and although test connection works, when sending a file - 'waiting.'
                        Firmware is latest rfg043463 from ricoh. What else??
                        No firewall, open port 3670 just in case...
                        • ruben
                          The New Guy
                          • Oct 2012
                          • 1203
                          Make sure you are giving the correct username and password (Windows 8 uses an online username, which I believe cannot work, but I haven't tested) and give the username permissions to read and write to the directory. Also disable any security suites and anti-virus, to test.
                          • Dexor
                            • 223
                            Originally posted by ruben
                            Make sure you are giving the correct username and password (Windows 8 uses an online username, which I believeIts cannot work, but I haven't tested) and give the username permissions to read and write to the directory. Also disable any security suites and anti-virus, to test.
                            thx. I had to create new destination/folder then magic happened. For some reason windoze hangs on to its bad experiences. It's all good now.
                            • solorajder
                              • Jul 2010
                              • 106
                              Great. It works on MPC3000 !!!
