Ricoh Aficio 2035
  • tcypy1961
    • 773
    Ricoh Aficio 2035
    What causes the screen to change on this copier to the loading toner message when a new cartridge of toner is installed? Thank you for any help given.
  • nmfaxman
    • 1702
    Re: Ricoh Aficio 2035
    It is catching up the toner to carrier ratio.
    • HP:guy
      • Feb 2013
      • 279
      If I understand your question, after the front door switch is actuates the it watches the TD sensor until proper mix is reached.
