MP 3350 tray jaming
  • iscott
    • Mar 2010
    • 344
    MP 3350 tray jaming
    MP 3350 both trays jamming.. feed tires and pads are new. Clutch maybe?
  • rthonpm
    • Aug 2007
    • 2852
    Re: MP 3350 tray jaming
    Also check the paper sensors in the behind the paper trays connected to the mainframe of the machine: users can bash those out over time and all kinds of chaos happens.
    • iscott
      • Mar 2010
      • 344
      Thanks..
      • sandmanmac
        • 3981
        I agree 100% with rthonpm. If it's a non-feed type jam, there's a bulletin about it. In place of the mylars recommended, i usually just put a little dab of glue on a couple of 'legs' of the sensor to hold it.
        Non-Feed Jams.PDF
        • rthonpm
          • Aug 2007
          • 2852
          Another potential solution is to unplug the size sensors and manually set the tray sizes in User Tools. This will prevent the issue from happening, but has a few drawbacks, namely if the user puts another size paper into one of the trays unless the size is changed in User Tools it will never work. I would mainly use this in LTR only environments where the machine was either low volume, or in a dirty environment (construction sites, etc).
          • iscott
            • Mar 2010
            • 344
            Sensors where broke thank you.
