Ricoh 2018 with Scanrouter V2 Lite / XP professional
  • choams
    • Jun 2025
    Hi,
    I have A Ricoh 2018 set up with Scanrouter
    V2 Lite.
    It is installed on a Windows XP professional machine which is set to act as the delivery server. I have, from Scanrouter, been able to identify the I/O device, but, the MFP is
    NOT picking up the destinations and senders from the delivery server.
    Delivery option is selected for File transfer and the MFP picks up the correct IP
    Both are set up static IP.
    The delivery folder is shared with full permissions.
    JC
  • sandmanmac
    • 3979
    Re: Ricoh 2018 with Scanrouter V2 Lite / XP professional
    It sounds like you have some experience setting up Scanrouter, so I'm assuming that you've also properly added the users within the program, Opened TCP port 3670 in windows firewall, etc.
    So are you saying that when you press "quick dial" (key #1) for example, it says 'no destination programmed' (or whatever)?
    Silly question, (because it has fooled me more than once).... Any chance that the quick dial flap is flipped over and is actually showing destinations 17-32 instead of 1-16?
    • KenB
      Geek Extraordinaire
      • Dec 2007
      • 3944
      Doesn't that flap have a little tab on it that trips a (very) microswitch?
      • sandmanmac
        • 3979
        Yes, but what i'm saying is that if you're not paying attention ( as I'm known to do), you could be pressing #17 when you think your pressing #1 ...thus "no destination is programmed"
        • choams
          I do not really have much XP with it. Just been reading the forums. I have added the users within the program, but I have yet to check port 3670 in Windows Firewall. I will check that first thing tomorrow though.. And re-post after. Thanks for the idea. 👍👍
          • sandmanmac
            • 3979
            Originally posted by choams
            I do not really have much XP with it. Just been reading the forums. I have added the users within the program, but I have yet to check port 3670 in Windows Firewall. I will check that first thing tomorrow though.. And re-post after. Thanks for the idea. 
            Port 3670 is must if windows firewall is running. I think that will do it for you.
            Also, if you haven't already done so, the PC should be set with a static IP address, otherwise Scanrouter will lose connection on a regular basis.
            Good luck, and let us know
            • Tonerbomb
              AutoMajical Resolutionist
              • Feb 2005
              • 2589
              Will scanrouter not DIE??????? and for what Sandmanmac said , I ask what SP is your xp running? Sp2 and SP3 really F'ed up SR.
              Mystic Crystal Revelations
              • choams
                Thank you Sandmanmac,
                The port issue is precisely what the main issue was. Once I opened TCP for that port, the destination list updated without fault.
                • choams
                  It is Win XP Pro SP3
                  • skinnyb
                    • Jul 2008
                    • 291
                    You can say that again!
