This will be the first Pro series machine I've encountered. As a tech, is this a decent machine? Hopefully better than the MPC7501 I recently added to my territory. I've renamed it "the beast".
Getting a Pro C901S.....
Tags: None
Re: Getting a Pro C901S.....
not support the entire life cycle. -
Do you know what will be printed on it?Comment
We have 3 unit's full option so far most i've encounter is the ITB cleaning unit Waste Clogging its a good machine but try not to load to much of 300 gsm media fusing belt would worn out easily..fix the customer first then fix the machine... its simple and makes life more easy.Comment
Sent from my LG-P769 using Tapatalk 2Comment
Thanks for the replies. You all have a great day.NEVER ASSUME ANYTHINGComment
