LCD CALIBRATION IN RICOH
  • kashif
    • Apr 2013
    • 45
    I have Pannel problem in my ricoh 2022, i want to know how i can calibrate this pannel,,can u help out me.
    Thnaks.
  • BYOUNGBLOOD
    Re: LCD CALIBRATION IN RICOH
    Press clear modes then 1>9>9>3 >red clear stop 5 times
    then press 1 ( on # pad) for calibration , touch top left corner , then bottom right , check pressing few areas then # , # to exit
    • ruben
      The New Guy
      • Oct 2012
      • 1203
      Please ask your questions here, in future: Ricoh, Savin, Gestetner
      • pereirataco
        • rza1013
          if that doesnt sort your problem out you might consider replacing the touch screen as factory fitted panels had a fault on them
          • Trainer1959
            If the touch screen calibration that others have mentioned here does not fix it, then you have to replace the touch screen. The touch screen actually lose their sensitivity after a while.
