Streampunch - help locating dies
  • langelot
    • Nov 2008
    • 85
    Hi Guys,
    I'm about to purchase a Konica Minolta Bizhub Pro 1051 with a GP-501 (Made by GBC) - The unit only came with a three-hole punch die set installed, but it looks like it has three empty spots for additional dies. The wholesaler had a Ricoh finisher with an eleven small-hole die that seems to fit perfectly and work just as well on the KM GP-501.
    I'm assuming this is the "StreamPunch" system. Can anyone confirm that my assumption is correct and if so, what is the best way to obtain additional dies (Konica, GBC, Ricoh?) or better yet does anyone have an extra die I can buy (44/43 holes - color coil?) or the designation for it?
    Pictures/diagram would be great (the KM model has a vertical metal bar with a hole lined with a rubber ring to pull out the die.
  • Imprestik
    • Aug 2012
    • 297
    Re: Streampunch - help locating dies
    The GBC streampunch is identical across all manufacturers. You should be able to contact your KM dealer which should be able to assist.
