MP C3000 copies come out with lines and distorsion
  • impaqsol
    • Jun 2009
    • 87
    I have a MPC3000 that prints awesome, but when I make a copy it comes out real bad with lines.
    I have been told that this can be solve in service mode.
    Thxs
  • sandmanmac
    • 3983
    Re: MP C3000 copies come out with lines and distorsion
    Thxs
    What's with your attachment? Is this a Black & white photo of a colour test page or something? It's pretty difficult to advise you on that one.
    • rthonpm
      • Aug 2007
      • 2859
      Looks a lot like bad RAM, but if the prints are good then maybe not... Do the lines clear up if you turn the machine off and then back on? Firmware up to date?
      • impaqsol
        • Jun 2009
        • 87
        Thxs for responding so fast. This copies that I've made are in b/w, but it's a color copier. It doesn't matter if copy is b/w or color it come out with lines. Here is another photo I took.
        Hope this photo is more clear.
        Thxs
        • Debs1964
          • Oct 2010
          • 1693
          Try doing a memory clear on copier application only
          There are 10 types of people in this world, those who understand binary maths and those who don't
          • teebee1234
            • Jul 2008
            • 1670
            Ditto, I've seen this before and I'm almost positive it was a memory dimm. But like stated by rthonpm, I would think prints would look the same. Try reseating them on the controller. The pattern suggests a memory buffer problem of some sort. After that then do a SBU test pattern, this will tell you if the problem is with the scanner (SP4907). From there move onto the IPU test patterns (SP4417).
            • nmfaxman
              • 1702
              Bad original read in scanner.
              Print a meter sheet.
              If it is good, the scanner has a problem.
              Try copying meter sheet in service mode with single color copying with each color to see if the same pattern shows on each color.
              Check scanner white plate and mirrors for film or distortion.
              As always................................
              • Iowatech
                Not a service manager
                • 3930
                Thxs
                Um, I didn't see this yet, so, sorry if this is wrong.
                But, have the optics been cleaned? If the machine prints well but has errors when copying that's a pretty good indication that either the optics are contaminated or the SBU has failed. Although the times I've seen the SBU fail has resulted in somewhat more unusual patterns than what your photos show, so that is kind of unlikely from what I can tell.
                • zames77
                  Tweak it till it breaks!
                  • 121
                  I'd put my money on the BICU (IPU) or the CCD's. Check out page 209 of the service manual for Scanner Test Mode.
                  • impaqsol
                    • Jun 2009
                    • 87
                    Unfortunately I don't have the service manual for this model.
                    Rad
                    • Debs1964
                      • Oct 2010
                      • 1693
                      Rad
                      Where's Paul when you need him
                      • impaqsol
                        • Jun 2009
                        • 87
                        Teebee,
                        You are right on the money, took the memory dimm and cleaned them reseated them and BAM it worked.
                        Thanks guys for all your input.
                        Rad
