Ricoh 2027 printing problem
  • slim
    • Jan 2008
    • 30
    Lately I have a machine that will not print jobs unless you turn the copier off and back on. It will work for a while and then do the same thing. They cannot wait until I get out there to see if i can ping the machine to see if it is dropping off the network. Hooked my laptop up to it and /t ping with no problem. Tried new hard drive and reload firmware. Any suggestions. Thanks
  • cobiray
    Passing Duplication Xpert
    • Mar 2008
    • 1199
    If they are using DHCP, you might have their IT staff verify the IP is reserved, so that nothing else picks up that IP.
    Also, if they are having to reboot their server, the copier will need rebooted to re-establish a network connection.
    • caini12345
      i have expierenced one time ,there is a pc with the same ip address ,turn off the copier and then ping the ip,if you can still ping it ,try to change the ip address.
      • unisys12
        • 489
        Further more, I would run IPCONFIG on a few of the PC's to get an idea of the range they are placed in and reprogram the MFP outside of that range. In other words, if you find that the PC's are from 192.168.1.125 - 192.168.1.150, then I would put the MFP at say... 192.168.1.50
        Other than that, you could possible have a faulty NIC card.
        sigpic
        The first law states that energy is conserved: The change in the internal energy is equal to the amount added by heating minus the amount lost by doing work on the environment.
        • Froota
          Field service tech.
          • 129
          Hello,
          You could try to ping with '-t' behind to see if there are obstacles, maybe while you are moving the utp cable or the connector in the nic card. (not vissible in a short ping.)
          We had have some problems with bad installed nic cards. therefor a possibility is re-installing the card, and make sure while mounting the screws to the frame, the card is well connected to the controller board. then try again.
          Good luck,
          Froota
          • fausto1981
            IT Technician
            • Dec 2007
            • 145
            you took the words out of my mouth, that is exactly what i was going to tell you.
            turn off the device, ping it and if you still get a reply then you have an IP conflict. The weird thing is that Ricoh machines tell you if there is an IP conflict they even show you the MAC address of the other device using the same IP.
            I had that problem once, right after I setup the MFP, someone else came to install a camera, guess what the guy used the same IP address.
            • Jomama46
              • 2900
              It could also be a bad port on their switch. Link lights dont mean squat at times. IT will try to blame it on the machines nic but it only takes a minute to change to another switch port.
              sigpic
              A+; Network +; PDI+
              • SGT_Snacks-64
                • Oct 2007
                • 157
                Good luck if you got to deal with any IT Admins
                Intel Core 2 Quad Q6600 2.4GHz (Oc'ed to 3GHz - Stock Volts)
                Asus P5E-VM HDMI
                4GB (2x 2GB) Corsair XMS Xpert II RAM
                ATi Radeon 4870 512MB GFX Card
                2x 74GB WD Raptor Sata HDD (RAID 0)
                500GB Seagate Barracuda Sata II HDD
                500GB Hitachi Sata II HDD
                600W500att OCZ PSU
                -TOTAL HDD SPACE 1148GB-
                • Jomama46
                  • 2900
                  Right, some of them can be quite defensive about their stuff (read job)
                  sigpic
                  A+; Network +; PDI+
                  • SGT_Snacks-64
                    • Oct 2007
                    • 157
                    I've had a lot of problems in the past with customers using FAX Through Ethernet cables, and the IT Admin's claiming it's "the machine!" when it clearly isn't. Sometimes they're ok, other time's they can be pretty arrogant "Of course... not ALL of them."
                    Asus P5E-VM HDMI
                    600W500att OCZ PSU
                    • Jomama46
                      • 2900
                      I'm sure they same the same thing about 'those fricking copier techs"
                      LOL
                      sigpic
                      A+; Network +; PDI+
                      • fausto1981
                        IT Technician
                        • Dec 2007
                        • 145
                        As an IT tech I feel the same way about my network.
                        As a copy tech, I hate IT guys they are very arrogant, but I know alot of tricks to prove them wrong.
                        • copyman20
                          • 207
                          Did you ever get a resolution to the problem you were having? If not, check which driver your customer prints from. If they are using PCL6 try PCL5e. Some times with PCL6 if you send a big job to the printer, (documents from the web) it will stall and lock up the printer. If they are using PCL5e then try using RPCS and shift load to driver in the print configuration in printing preferances.
                          Good Luck
