mpc 2500 sc 672
  • ash_572
    • Oct 2008
    • 523
    mpc 2500 sc 672
    i have an mpc 2500 with an sc 672.
    ive read the manual but it only throws the sc code when we plug the network cable into the machine.
    recently their network crashed and the machine gave an sc 672. and now everytime they plug the ethernet cable in to their controller the screen freezes and throws an sc 672. unplug the ethernet and it works fine.
    i disconnected the HDD and its the same.
    does this mean that theres a problem with their network or is it the machine???
    any idea??
    thanks
  • sandmanmac
    • 3979
    Re: mpc 2500 sc 672
    Check fax connection to FCU. Also try it with fax option disconnected. Update system firmware.
    Otherwise, it's most likely control board
    • ash_572
      • Oct 2008
      • 523
      Re: mpc 2500 sc 672
      hi. i have connected the ethernet to my laptop without any problems.
      theres is no fax module on this machine and all firmware is upto date.
      i will speak to our network man
      • Zeldaman
        • Mar 2011
        • 946
        Re: mpc 2500 sc 672
        Hi there!
        Had the same problem with a MPC 5502: sytemcrash at the customer, cable in, sc-code. Astonishingly there were some corrupted prints on the way, which were several weeks(!) old. After deleting them the problem was gone.
        Greetings...
        • ash_572
          • Oct 2008
          • 523
          Re: mpc 2500 sc 672
          Originally posted by Zeldaman
          Hi there!
          Greetings...
          Thank you for your reply.how did you manage to delete the documents??
          • Zeldaman
            • Mar 2011
            • 946
            Re: mpc 2500 sc 672
            Hi there!
            To my great pleasure the admin was availible, and he deletes the datas from his PC . What also can help is, that evry user open his printer-menue to check if there are old datas on the way. Hope this helps.
            Greetings...
            • Codex
              • May 2008
              • 701
              Re: mpc 2500 sc 672
              Had the same problem with an Aficio 1022!!........i my case it was the router that had a faulty port.
              Memento Audere Semper
              • minhphu
                Re: mpc 2500 sc 672
                any idea??
                thanks
                you can try with the way :
                - check dipsw on BICU board is defaut?
                - try to update firmware
                • CableGuy
                  Impulse Drive Engineer
                  • Oct 2008
                  • 417
                  Re: mpc 2500 sc 672
                  We're having this problem with one of our Mpc2500's. They customer had new internet supply installed and since then when the network cable is plugged in you get an error code and the machine freezes up. Unplug the network cable and it works fine. It looks like there is a bulletin out about this. If you can prove it works from your laptop the they have an IT issue.... not your problem.
                  • Klydon
                    • Mar 2009
                    • 243
                    Re: mpc 2500 sc 672
                    I had this issue as well. It was some sort of corrupt PDF file the machine kept choking on. Had a user delete it from the print que. Other files printed fine. Did a test print and it was fine.
