MP 2852
  • Voltage
    • Jul 2008
    • 282
    MP 2852
    HI Guys
    I have 2 MP2852 that are giving me trouble.
    On the one only the power light in the top right hand corner comes on. We have received a bulletin stating that there is a problem on some of the controllers with a certain chip number, that cause this problem. Same with some of the IPU board. I have now changed both these. Now the screen at least comes on but only shows please wait. Also there is a relay on the PSU that keeps engaging. on/off/on/off. If you turn of the machine it does give you the "Machine is shutting down please wait 2 minutes" message
    The other one does exactly the same, Also with a new controller. But his relays are not engaging. Just shows the Please Wait message.
    I have disconnected both machines HDD.
    Any ideas??
  • Voltage
    • Jul 2008
    • 282
    Re: MP 2852
    Originally posted by Voltage
    HI Guys
    Any ideas??
    Solved. Ribbon was not in properly. ID10T error
    • Polarbear
      • Feb 2012
      • 1070
      Re: MP 2852
      I have one that is booting, then just before the PLEASE WAIT turns to a Home screen - it throws a SC672.
      That I can still handle, but the twist is that you can hear relays click on the low voltage psu, with about 2 second intervals.
      I'm thinking that the PSU is the cause but am still waiting for tester boards to arrive....
      Press the GREEN button!!
      • HP:guy
        • Feb 2013
        • 279
        Re: MP 2852
        I read that there is special firmware form these machines.
          • 37532
          Re: MP 2852
          On older machines this was a symptom of a bad HDD. Try disconnecting the HDD. If it then boots to the home screen, then replace the HDD.
          • JustManuals
            • Jan 2006
            • 9838
            Re: MP 2852
            Paul@justmanuals.com
            • de144
              • Feb 2012
              • 15
              Re: MP 2852
              Voltage
              I have one doing the same thing. replaced controller, IPU, PSU. Now tech support is saying NVRAM. What was not connected that you were able to solve your issue?
              • Voltage
                • Jul 2008
                • 282
                Re: MP 2852
                Hi
                If i remember correctly it was the white ribbon cable.
                • de144
                  • Feb 2012
                  • 15
                  Re: MP 2852
                  Voltage,
                  Thanks for the reply
                  Was that the ribbon cable on IPU? I'll be sure to check them again before we replace the NVRAM.
                  • de144
                    • Feb 2012
                    • 15
                    Re: MP 2852
                    As you said the ribbon cables to the IPU were not seated correctly. Machine came to ready then SC899. Updated firmware that went well until the scanner update failed. Always remember to make sure the print/scan dimm is in the unlock position.
                    • 1nevster
                      • Dec 2010
                      • 49
                      Re: MP 2852
                      If SC 672 -replace the controller.
                      If it displays Please wait and no error -replace ipu board.
                      Ricoh are aware of these issues.
                      • Ricoh-ono
                        • 338
                        Re: MP 2852
                        I had one last year with a blue light failure. The board on the lens holder assembly was bad. Machine had less than 100 copies.
                        Do what you can, with what you have, where you are. ~Theodore Roosevelt
                        • wilbert.c
                          • Apr 2014
                          • 24
                          Re: MP 2852
                          did you try to disconnect all options one by one ? it may work also
