ricoh aficio mp-c3500 sc452
  • copierguy1
    • May 2025
    [Error Code] ricoh aficio mp-c3500 sc452
    replace duplex housing. now getting sc452 error. any help would be appreciated.
  • rsyarcia
    Hair Straightener Tech
    • 711
    Re: ricoh aficio mp-c3500 sc452
    do you have a service manual for this machine? check the connectors maybe you forgot something..
    Nobody is perfect..
    • JustManuals
      • Jan 2006
      • 9838
      Paul@justmanuals.com
      • copierguy1
        Have taken it apart 3 times. code goes away then shows misfeed which there is not one.
        • teebee1234
          • 1670
          Is this replacement duplexer from another of the exact same model or a different model that looks the same? Sometimes extra sensors are added or removed between models even though the mechanical components are unchanged.
          • sandmanmac
            • 3963
            Let's back up and find out what led to this condition...
            Why did you replace the duplex housing in the first place?
            So there are no "SC" codes anymore?
            The more info you provide, the easier it will be to help.
            Also, If it shows "misfeed" now, what codes is it logging?
            • copierguy1
              customer abuses machine. part is new from ricoh. aficio mp-c3500. if it is not showing sc452. it says misfeed in area c.
              • sandmanmac
                • 3963
                So, you're apparently a man of few words. Fine.
                "misfeed in area c", is NOT the "jam code", and SC452 has nothing to do with duplexer, so My few words to you, are "Good Luck"
