Ricoh Aficio 1075 don't remember anything ( IP address, clock) Etc.
  • m_donakov
    • 213
    Hi all
    I have ricoh aficio 1075 and i have problem that machine do not remember anything. I can set IP address and work fine until i turn of main switch. After that everything back to default.
    What can be ?
    Thanks Regards
  • rthonpm
    • Aug 2007
    • 2854
    Re: Ricoh Aficio 1075 don't remember anything ( IP address, clock) Etc.
    I think this unit has a battery on the controller to save all of these functions: it may have failed. If not, then the NVRAM may be going flaky.
    • m_donakov
      • 213
      Thanks for answer, i thould may be battery but where to find it? In theprinter controller?
      • SGT_Snacks-64
        • Oct 2007
        • 157
        The Battery "should" be on the controller from what I remember. You can test the battery when removing it by running a Multi-meter across the Positive and Negative of the Battery and comparing the output voltage with what's stated on the battery. As this is an older model machine, this doesn't surprise me that the Battery may have failed.
        New ones are cheap, so long as the battery isn't hard-wired into the board. If it is then things may get a little more expensive.
        Intel Core 2 Quad Q6600 2.4GHz (Oc'ed to 3GHz - Stock Volts)
        Asus P5E-VM HDMI
        4GB (2x 2GB) Corsair XMS Xpert II RAM
        ATi Radeon 4870 512MB GFX Card
        2x 74GB WD Raptor Sata HDD (RAID 0)
        500GB Seagate Barracuda Sata II HDD
        500GB Hitachi Sata II HDD
        600W500att OCZ PSU
        -TOTAL HDD SPACE 1148GB-
        • Lotar
          • 76
          I have had to do this on various Ricoh models in the past even "hard wired" and it took care of that same symptom/problem.
          • ccchuah
            • Mar 2009
            • 157
            You have to replace the NVRAM because the battery is store inside the NVRAM.
            • mikadonovan
              • May 2008
              • 2931
              Bingo!
              NEVER ASSUME ANYTHING
