"updating @remote certificate"
  • Jomama46
    • 2900
    I have a C2050 that is flashing this message. Anybody know the source and how to turn it off? It is not using @Remote.
    sigpic
    A+; Network +; PDI+
  • TonerMunkeh
    Professional Moron
    • 3865
    Re: "updating @remote certificate"
    I think.... SP5-816-209 clears the @remote settings to default. After a reboot the message shouldn't show again. It has, at some point, had @remote on it, whether it be from a Basil box or via the Cumin side.
    Hit it.
    • Jomama46
      • 2900
      sigpic
      A+; Network +; PDI+
      • sandmanmac
        • 3981
        I've not tried the the SP TonerMunkeh provided, but when I've run into this, I've set SP 5816-001 to "0" (Remote service Off) and then reboot machine
        • Jomama46
          • 2900
          sigpic
          A+; Network +; PDI+
          • SargeNZ
            • May 2012
            • 263
            Are you sure it is still not registered under an old client? I have never seen this message on a machine that was not connected (or still trying to connect) to the @remote server.
            It is a known issue currently with @remote, To clear the message and get @remote working again we have been doing 5816-209, then 5-870-3 (common keyinfo initialise), and then 5-870-1 (common key info execute)
            The machine then needs to be re-registered under a new @remote number (after removing the device off the @remote servlet).
            • Jomama46
              • 2900
              This is a used machine that was purchased and refurbed.
              sigpic
              A+; Network +; PDI+
              • pocket aces
                Ricoh Technician
                • Nov 2008
                • 72
                I have a few of these doing this now .I will post if I find something
