Ricoh 3035 ADF jam with more than 5 pages
  • shad0wguy
    • Jun 2025
    I had a coworker try to copy a document today and the adf on our Ricoh 3035 would jam when any amount of pages beyond 5 or so were loaded. It sounded like the roller that feeds the adf was slipping, but I could be mistaken. What are potential solutions to fix this machine?
  • zsoltee0001
    • Jul 2009
    • 39
    • ruben
      The New Guy
      • Oct 2012
      • 1203
      Re: Ricoh 3035 ADF jam with more than 5 pages
      Are the rollers or belt worn? If so replace, otherwise if they still have a bit of tred you can try cleaning them. Usually IPA is enough to clean them.
      If you want to replace then the (original*) codes are: B351-2222 Feed Belt, B351-2126 Pickup Roller (very rare to need to replace), A859-2241 Reverse Roller.
      * May have changed since parts guide was produced.
      • Drummer
        • Feb 2013
        • 46
        If it is not the feed tires, you can pull the front panel off the df, and look at the center of the large plastic pulley, it sometimes gets small cracks in it right around the center shaft. The shaft spins inside the pulley causing erratic jams.
        • TonerMunkeh
          Professional Moron
          • 3865
          I'd go for replacing the belt, feed roller, sep roller and torque limiter before going after clutches. This DF is fairly bulletproof, clutches don't fail on them very often.
          Hit it.
