I have a MP 3300, another tech has been working on it and now I have ownership of the problem.
Machine boots up with an error 204 Polygon motor error XSCRDY signle error. Looking in the logs there is also a 492 Hi Voltage leak with it. On examination the yellow drum has toner covering it.
Once before I had the 492 error, the brass bushing e-clip fell off the developeing unit right into the HV contact, no easy fix this time though. The machine did not have these problems before a toner pump and drum were changed. I am slow to blame boards, and since the codes happened at the same time I tend to think they are related and the problem should be simple and just something I am missing.
Just looking for suggestions, it's got me stumped.
