FAX report setting of ricoh MFP
  • xlbizs
    • Jun 2009
    • 66
    Hi All,
    this is regard my customer Fax report setting on their Aficio MP3010, all fax report already off except the journal through the P/setting at 03. Now only unsuccessful transmission will have the report but with 1st page image. now customer wanted no image on all reports. we cant find any way (fax setting / SP Mode) to set.
    Thank.
    TIAN
  • totoro
    • 568
    Re: FAX report setting of ricoh MFP
    I think it's P switch 4 bit 7 set to 0 to turn off the image.
    Totoro
    • ruben
      The New Guy
      • Oct 2012
      • 1203
      In the same place where you set the Fax parameters, you can print off the parameter list, there it will tell you which soft switch to change.
      • xlbizs
        • Jun 2009
        • 66
        Hi totoro, thank, thing done.
        Tian.
