Ricoh MP4510 Drum?
  • blackdog
    • Jun 2012
    • 211
    Ricoh MP4510 Drum?
    Hey I'm about to swap out a drum and blade on this box (Savin/Ricoh MP4510) but for the life of me, can't find my doc on proper resetting of gear used for pg. counts. I had done this successfully a few years back and memory fades me on procedure. I goggled with no luck. Maybe one of you aces have a link or diagram. Thanks, and over and out.
  • TonerMunkeh
    Professional Moron
    • 3865
    Re: Ricoh MP4510 Drum?
    Do you mean an AP4510?
    Hit it.
    • blackdog
      • Jun 2012
      • 211
      Ricoh AP4510/SavinMLP45------One in the same.
      What say you.
      • blackdog
        • Jun 2012
        • 211
        Hold on I getting a flashback!
        Half moon gear turn 180? Which way Clockwise or Counter clockwise?
        I remember having to be correct or BINGO broken gear.
        • blackdog
          • Jun 2012
          • 211
          Hey I finally figured it out. Jot all SP settings i.e. vsg,vsp etc. down before doing this otherwise TD sensor will be off mark. Tape micro switch closed on inside frame where PCU rear meets gears. Install PCU, turn on, PCU count will reset, turn off. Access SP mode remove tape from micro switch, make necessary corrections to any SP settings that have been changed. Good for another 150k or until trash time.
