ricoh 2055
  • vargue
    • Oct 2011
    • 404
    [Jamming] ricoh 2055
    i have misfeed in tray2 and try 3 but tray 1 is OK. i clean clutches in both traction unit it's good .msfeed happens after 20 paper.please any suggestions,did that happens due to over load on traction motor
  • Polo-022
    • Sep 2007
    • 486
    Re: ricoh 2055
    Do you mean AF-1055?
    If yes, check the relay clutch (AX20-0207), below tandem tray feed head.
    • vargue
      • Oct 2011
      • 404
      Re: ricoh 2055
      thanks for your answer i changed all unit with clutch below tandem tray and problem still.i also checked gears in unit it's good and black gear from behind power supply . i swapped unit 3 in place of unit 1 it's working.and belts behind power supply it's good .i'm frustrated in this thread
      • Lagonda
        • Aug 2008
        • 1649
        Re: ricoh 2055
        Due to the age of this copier I would think that the clutches are to old to clean and i would fit new ones. Also replace all the torque limiters on the sep rollers.
          • 37547
          Re: ricoh 2055
          The only 2055 I am aware in the Ricoh Family Group is the Savin 2055DP. If this is the case and the machine has more than a million copies on it, replace the relay clutch on the first feed module. As a quick check, you can swap the clutches between the first and third feed modules. A worn clutch causes variations in the gap between individual sheets of paper which can be reported as jams at the registration roller.
          • Butrus
            • Jan 2012
            • 115
            Re: ricoh 2055
            I would also check everything that has to do with registration roller
            Pull out the unit and check everything
            • vargue
              • Oct 2011
              • 404
              Re: ricoh 2055
              i take off all registration unit and clean it well.i also swapped clutches to other units.
              • Exok
                • Jun 2011
                • 750
                Re: ricoh 2055
                Try replacing clutches instead of swapping them. With that many copies you can have multiple worn clutches and people before you may have already swapped clutches to the point of most of the clutches being equally worn. Also, check to see if this machine has had developer leaks in the past (or present). DV leaks on this machine fall right down into the clutches.
